Alt 09.09.2010, 19:27   #1
Miko
Benutzerbild von Miko
Standard GTti aus Polen
Hi
Im. sorry but my written German is very bad So I'll write in English.
I've bought a GTti in 2009 it was a mess. I've changed thebodyshell and repaired the faults. Added some extras like custom downpipe and full stainlees steel exhaust, some gauges and BOV
Currently the car makes 102,5PS on the dyno byt the AFR is about 14 so it needs to be reduced.
Current pics.
Uploaded with ImageShack.us
I heve a problem now. My turbo boosts too much (0.9bar) instead of 0.6-0.7 I've done nothing to the ECU, so I dont know where is the problem. I chnged the solenoid but still nothing. When driving normaly the boost is about 0,5 but when i "push the pedal to the metal" it jumps to 0,9 - its not healthy for the engine. Where is the problem?
Miko ist offline   Mit Zitat antworten
Alt 09.09.2010, 20:12   #2
hi, your problem is your downpipe !!
Alt 09.09.2010, 21:11   #3
Axi
Benutzerbild von Axi
To correct your problem, you have to change the Wastegate...
Maybe you can make the hole much bigger or change the pressur tin(Wastegate-Actuator).
Charade G100 GTti(BJ89,rot)
2x Applause A101
4x Cuore L80
7x G100(RIP)
Geändert von Axi (09.09.2010 um 21:33 Uhr)
Alt 09.09.2010, 22:50   #4
kiter
Benutzerbild von kiter
jepp. and the exhaust... if the diameter is bigger than original one
Alt 10.09.2010, 15:00   #5
Miko
I've made the complete exhaust on the basis of Camskill inventions. What is wrong with that?
I don't think that that's the case.
I was thinking more about the solenoid or waste gate...
Alt 10.09.2010, 15:07   #6
less restrictive exhaust> more boost !!!
Alt 10.09.2010, 15:22   #7
Miko
I wasn't expecting that much boost from this modification. :)
Anyway I will try to bore the wastegate a bit. Maybe this will help.
Alt 12.09.2010, 15:28   #8
kiter
built a fcd, than you won´t have the problems
Alt 24.05.2011, 15:33   #9
Miko
It's been a while :)
The car is currently being painted (NH -0 from Honda Integra) -big premiere next week:)
Ive added adjustable coil-overs at the front (from Golf 3er)
Changed some rubber parts in the suspension to polyurethane
I also mounted a turbo-timer and rear strut brace (needs to be re-done)
Pictures soon:)
Alt 18.07.2011, 22:42   #10
Miko
Small update :)
Cambers
Down pipe wrap
Timer
Currently fighting with major leak in the gearbox:/
Geändert von Miko (18.07.2011 um 22:44 Uhr)
Meine Gtti Restaurierung turbotwin Die Charade Serie 42 19.07.2025 17:36
Alle Zeitangaben in WEZ +2. Es ist jetzt 04:43 Uhr.
