Zurück   Daihatsu-Forum.de > Daihatsu Weltweit > Daihatsu International
Daihatsu International Alle restlichen Daihatsu Zweigstellen und Tochter/Mutter Konzerne
Alt 01.04.2004, 00:20   #21
Val Brown
Benutzerbild von Val Brown
Hallo!
Ich bin neu in diesem Forum und ich kann Englisch viel besser als Deutsch . Also vielleicht kann ich hilfen. Der Sirion Rally Modellen sind eigenstandige und stehen nur in England zu Verfügung. Ein englischer Tuning Company (Auto Image von Bedfordshire) hat beide getunt. Sie haben Sportluftfilter, Chiptuning, Tieferlegung, kürzer Kraftübertragung, neue Bremsen und Sportauspuff. Der Rally4 ist ein allrad Version.
Grüß, Val
Val Brown ist offline   Mit Zitat antworten
Alt 01.04.2004, 02:30   #22
Mannheimer
Viele Dank Val, für alle nochmal hier die Englische Beschreibung:
With the help of Bedfordshire-based Auto Image Limited, Daihatsu UK's technical department set out to extract more power and enhance the cornering and stopping ability of the already zingy 1.3-litre Sirion. To their
ADVERTISEMENT
dismay they discovered that conventional high-tech tweakery wasn't the answer, as any fiddling with the ignition timing or fuelling was eventually compensated for by the Sirion's HAL-like ECU.
With silicon trickery failing miserably, Daihatsu and Auto Image maximised the Sirion's potential by fitting a free-flow air filter and a reprofiled exhaust camshaft, which works with the Sirion's standard DVVT variable valve timing system to deliver earlier and more prolonged lift. The result is a hard-won increase in power and torque, from 101bhp and 88lb ft to 107bhp at 7100rpm and 94lb ft at 6000rpm. With the same power for both front-wheel-drive Rally 2 and all-wheel-drive Rally 4, it's the lighter Rally 2 that is unsurprisingly the swiftest, with a very respectable 0-60mph time of 8.1sec and a top speed of 115mph. The Rally 4 follows with 8.9sec and 112mph.
To sharpen the handling, a set of 15 per cent stiffer and 20mm shorter springs have been fitted, together with good-looking seven-spoke 15in alloys wearing 175/55 tyres. For increased bite and resistance to fade, the brake pads have been uprated, while a short-throw gear linkage makes the shift more snappy.
As you can no doubt tell from the power and torque figures, you need to thrape the poor little Sirion within an inch of its life. But having bombed around some of Bedfordshire's finest B-roads, not to mention terrorised members of the MG Owners' Club at a Bedford Autodrome trackday, there's no-one more surprised than me to say the Rally Sirions are unlikely but entertaining machines.
Weapon of choice is the Rally 2. It feels faster in a straight line, and come the corners there's more throttle adjustability than the heavier (900kg against 850), less nimble Rally 4. There's less roll than you'd expect from such an upright looking hatchback, and although there's still limited feel and modest turn-in by, say, Mini One standards, there's a neutral balance and poise that allows you to maintain a surprising pace. The brakes are strong and remarkably fade free and, though noisy, the free-revving engine (the Sirion uses a more highly tuned version of the Toyota Yaris's powerplant) has an unburstable feel and a strong top-end yet can also return 55mpg.
With ABS, air-conditioning, a CD player and a five-year warranty as standard, the £9995 Rally 2 and £10,995 Rally 4 offer a lot of fun for not a lot of money. Quite who's going to buy either of them is hard to say, especially when there are some seriously capable used hot hatch icons, such as the 306 Rallye or Saxo VTS, for considerably less money. But, unlikely though it may sound, if you want ultimate new-car peace of mind and a sprinkling of evoness on a tight budget, a Sirion Rally 2 or 4 is genuinely worth a look
Gruss Torsten
P.S. Jetzt sollten alle ungereimtheiten beseitigt sein, also diese Firma ist der Englische Daihatsu Haus Tuner.......
Alt 02.04.2004, 09:13   #23
Samurai
kann ja auch sein, dass das Getriebe so kurz untersetzt ist, dass er tatsächlich so schnell beschleunigt, dafür ist/wäre dann die Endgeschwindigkeit nicht so hoch; ausserdem denke ich, dass der Sirion ein paar Kilo leichter als ein YRV ist,macht auch was aus.
Grüsse
Samurai
Samurai ist offline   Mit Zitat antworten
[Bolle Bollerwagen] Und ich hab es doch getan . . . Yin Die Cuore Serie 838 28.05.2024 09:45
Farben bei Daihatsu - Was für ein Rot ist das? N-Lafesta Daihatsu Allgemein 8 24.05.2011 10:44
Alle Zeitangaben in WEZ +2. Es ist jetzt 19:24 Uhr.
