oha so langsam rutscht der groschen... un wo liegt nun das prob.. das macht alles mein Händler wenn was dran is
Jetzt dämmerts langsam, danke für die Erklärungen.
![]() Registriert seit: 29.03.2005
Endlich kann ich die meisten OBDSensoren im meinem L251 sehen.
Billig und sehr kompakt. http://www.omniauto.it/forum/index.php?showtopic=6786 Es is ein ELM323 OBD Geraet. Mein alias ist LucZan, wie hier MFG. Luca, Italy. |
#14 |
![]() Registriert seit: 02.09.2013
Hi every body,
I don't know if I am in the right thread but I really need a quick answer: On the DLC connector of my Cuore L251, when I put a shunt between the 5th pin in the top and the 5th pin in the bottom (just as shown on the label on the hood) I got the EPS indicator blinking as follows: 5..7......5..7......5..7..... etc I wonder what means this code? Thanks for your help. |
#15 |
any idea please?
#16 |
![]() Registriert seit: 02.10.2004
I know it's a stupid question, but are you really sure it's DTC 57 ?
I'm asking because I can't find that code in my L251 service manual... |
#17 |
My Cuore is L251, but EJ-DE engine.
As shown in the picture attached, taken from my hood, with a link between 5th and 13th pins, I was able to see the EPS blinking as described above: 5 times, short blank, 7 times, long blank, etc. |
#18 |
#19 |
The bridge shown on your photograph is the one to check ignition timing. To read out error codes, it is a different one.
Lets see, if I manage to find the Topic... give me some time for a trial please. If I manage to get it, I'll post the link.
#20 |
I Searched now for some time, and I found out, that your photograph shows the right pins to bridge to get the error messages via MIL.
http://www.daihatsu-forum.de/vbullet...-DE+Fehlercode In post #4 of the above link is the same problem mentioned as you described. Instead of the MIL, it was the EPS light blinking. Reisschüsselfahrer states there, that he then tried the pin besides that before an it worked. He wrote, that he just confused the pin-order... At your own risk then... The how-to here: http://www.daihatsu-forum.de/vbullet...t=16952&page=2 in post #13 is confirmed working, but the examples I found to confirm it working were all of EJ-VE vehicles.
| Zahle eins nimm zwei!!!! Cuore L251 Bj 04 1 Hand 134200km | pluschbeer | Die Cuore Serie | 14 | 18.12.2012 15:32 |
| Daten zum neuen Cuore 7. Generation | Inday | Die Cuore Serie | 61 | 09.08.2007 21:06 |
| Trevis genauso spritzig wie Cuore L251? | hai datsu | Daihatsu Allgemein | 9 | 17.03.2007 11:42 |
| Crash Test Cuore (L251) | Micha77 | Die Cuore Serie | 13 | 01.02.2007 21:44 |
| Sturz - Nachlauf - Spur Cuore L251 | LucZan | Die Cuore Serie | 5 | 09.01.2006 01:54 |
