![]() Registriert seit: 17.12.2019
Hello the ej-de 1000cc when is cold after some hours at parking i can hear tik-tik-tik sound from engine.
After some km the noice disappear. What is this noise? Can i solve it. |
![]() Registriert seit: 07.12.2018
Excessive clearance due to cold temperature. This is normal, since the clearances will reduce through high-temperature expansion. This is why it's always best to only drive the vehicle at operating temperature. Driving with a cold engine will reduce engine life through excessive wear.
Just to be sure, why not show us a video? |
I have video how to upload it?
---> youtube.com ---> Upload --->Copy a link to the Video into this forum.
Click 3 times on the first image, in order to have it fully enlarge:
Geändert von Bauer_Sucht_Sau (20.04.2020 um 07:57 Uhr) |
I post a video of a sound.The video is in the morning after the engine sitting 12hours swithing off.
As you can hear as the engine get hotter the tik-tik sound disappear. https://youtu.be/XTUHIiL1iNE |
Is it just after a long time (12h) or everytime when the motor is cold?
I suspect, this could be tappet noise. I would remove the camshaft covers and then measure the valve clearances, while the engine is cold
When the motor is warm the sound disapearing.
This engine have variable cam gear? |
With the warm engine no tik-tik sound
If i switch off and on again the engine when its warm the sound is the same. https://youtu.be/uFuGzv3peCA |
| richtiger pop off sound | Turborädi | Die Charade Serie | 11 | 05.07.2017 10:56 |
| Sound Einbau YRV | dante-yvr | Die YRV Serie | 23 | 17.02.2007 21:35 |
| Probleme mit sound..-.- | AppiDriver~1986 | Allgemein | 10 | 25.09.2005 22:11 |
| Remus Sound | Frog1971 | Die Applause Serie | 4 | 10.07.2005 21:59 |
| Sound im YRV | Rainer | Die YRV Serie | 7 | 11.08.2003 19:22 |
