Alt 08.04.2005, 14:57   #11
G200-Freak
Benutzerbild von G200-Freak
@Racemove
http://sg.pg.photos.yahoo.com/ph/cat...b0.jpg&.src=ph
hier siehst du mehr
Alt 08.04.2005, 19:47   #12
charadegti16v
Zitat von Rainer
Zitat von SlowPoke
wahhh..... must be trying to catch up with Ekin Cheng and Simon Yam's Evo & Wrx, so he set scramble boost on his boost controller and activate his wet system direct port NOS to spool up the Garrett T88 turbo. The full boost kicked in and the car surged forward, but this led to a temporary oil starvation situation as the engine oil pickup in the oil sump is sucking nothing but air, as the turbo is spinning at 150,000 rpms the bearing got hot very quickly and without the engine oil to lubricate and cool it, the bearing so hot that it expanded and blew up, spraying the inside of the engine bay with deadly shrapnel. One such piece severed the fuel line of the wet NOS system and ignited the fuel that sprayed out resulting in the fireball you saw in those pictures......
:drunk: :blackeye:
Something wrong there , nos itself doesnt burn.
see here http://www.holley.com/HiOctn/TechSer.../NOSTech5.html
quote:
Q: Is nitrous oxide flammable?
A: No. Nitrous Oxide by itself is non-flammable. However, the oxygen present in nitrous oxide causes combustion of fuel to take place more rapidly.
Alt 08.04.2005, 20:00   #13
dRunks
uiuiiu, sieht ja übel aus. Hoffe das dem Fahrer nichts passiert ist oder anderen!!
Bist du gierig wird es schwierig *gg*! Zumindest kann er noch die Felgen behalten
dRunks
Daihatsu, weils einfach besser ist ;-)
2003 - Auto: Alfa 145 1.4 16V Twin Spark
2004 Daihatsu Charade GTI 16V :D
dRunks ist offline   Mit Zitat antworten
Alt 08.04.2005, 21:32   #14
kiter
Benutzerbild von kiter
auf jeden fall mal übel
würde mich aber trozdem net davon abhalten das auch alles einzubauen *ggg*
Alt 08.04.2005, 22:03   #15
yeah, this was also my first thought, but this is a wet system, means that the thing has also injected fuel with the nozzle.
Alt 08.04.2005, 22:11   #16
kiter
richtig! und diese verbindung brennt ganz übel
Alt 08.04.2005, 22:53   #17
und er hatte ja offensichtlich zu wenig öl aufm kessel so wie ich das verstanden hab und ich glaub in der nähe eines so hochgezüchteten turbos isses so warm da brennt die luft......
MAnu
Alt 08.04.2005, 22:54   #18
kiter
da brennt in der tat die luft *gg*
und en bischen mehr wenn man net aufpasst *löl*
Alt 08.04.2005, 22:55   #19
ein turbo ohne öl, glühen da die lager schon rot???
MAnu
Alt 08.04.2005, 22:58   #20
MAnu
Turbos glühen auf mit Öl !!
Charade 1.3 zu Charade GTti?!?! JapanImports Die Charade Serie 10 26.04.2009 11:42
Bernhard GTti fährt 1 Jahr Charade GTti :)! BernhardGTti Die Charade Serie 7 13.04.2005 22:44
Ladedruck beim GTti erhöhen Bullet_GTti Die Charade Serie 0 25.02.2005 14:24
Welcher Charade GTti war den nun der letzte? Mannheimer Die Charade Serie 4 23.01.2005 01:23
Alle Zeitangaben in WEZ +2. Es ist jetzt 05:07 Uhr.
