Alt 09.09.2005, 18:31   #11
bueffel
oha so langsam rutscht der groschen... un wo liegt nun das prob.. das macht alles mein Händler wenn was dran is
Alt 09.09.2005, 19:51   #12
Jetzt dämmerts langsam, danke für die Erklärungen.
Alt 16.11.2005, 23:20   #13
LucZan
Benutzerbild von LucZan
Endlich kann ich die meisten OBDSensoren im meinem L251 sehen.
Billig und sehr kompakt.
http://www.omniauto.it/forum/index.php?showtopic=6786
Es is ein ELM323 OBD Geraet.
Mein alias ist LucZan, wie hier
MFG. Luca, Italy.
Daihatsu Cuore L251 Thrifty
LucZan ist offline   Mit Zitat antworten
Alt 19.06.2014, 14:33   #14
terios
Hi every body,
I don't know if I am in the right thread but I really need a quick answer:
On the DLC connector of my Cuore L251, when I put a shunt between the 5th pin in the top and the 5th pin in the bottom (just as shown on the label on the hood) I got the EPS indicator blinking as follows:
5..7......5..7......5..7..... etc
I wonder what means this code?
Thanks for your help.
terios ist offline   Mit Zitat antworten
Alt 20.06.2014, 22:05   #15
terios
any idea please?
Alt 21.06.2014, 17:31   #16
Rokko
I know it's a stupid question, but are you really sure it's DTC 57 ?
I'm asking because I can't find that code in my L251 service manual...
Rokko ist offline   Mit Zitat antworten
Alt 22.06.2014, 00:23   #17
terios
My Cuore is L251, but EJ-DE engine.
As shown in the picture attached, taken from my hood, with a link between 5th and 13th pins, I was able to see the EPS blinking as described above: 5 times, short blank, 7 times, long blank, etc.
Alt 22.06.2014, 00:27   #18
terios
Alt 22.06.2014, 01:03   #19
The bridge shown on your photograph is the one to check ignition timing. To read out error codes, it is a different one.
Lets see, if I manage to find the Topic... give me some time for a trial please. If I manage to get it, I'll post the link.
Alt 22.06.2014, 03:16   #20
I Searched now for some time, and I found out, that your photograph shows the right pins to bridge to get the error messages via MIL.
http://www.daihatsu-forum.de/vbullet...-DE+Fehlercode
In post #4 of the above link is the same problem mentioned as you described. Instead of the MIL, it was the EPS light blinking.
Reisschüsselfahrer states there, that he then tried the pin besides that before an it worked. He wrote, that he just confused the pin-order... At your own risk then...
The how-to here: http://www.daihatsu-forum.de/vbullet...t=16952&page=2 in post #13 is confirmed working, but the examples I found to confirm it working were all of EJ-VE vehicles.
Zahle eins nimm zwei!!!! Cuore L251 Bj 04 1 Hand 134200km pluschbeer Die Cuore Serie 14 18.12.2012 14:32
Trevis genauso spritzig wie Cuore L251? hai datsu Daihatsu Allgemein 9 17.03.2007 10:42
Crash Test Cuore (L251) Micha77 Die Cuore Serie 13 01.02.2007 20:44
Sturz - Nachlauf - Spur Cuore L251 LucZan Die Cuore Serie 5 09.01.2006 00:54
Alle Zeitangaben in WEZ +2. Es ist jetzt 17:45 Uhr.
