Alt 03.06.2009, 15:04   #11
magnum
Benutzerbild von magnum
oh das ist mal echt sehr nützlich!!!
danke
Alt 03.06.2009, 21:19   #12
Sonny06011983
@smateriato
You're welcome! Hope it works, just got it from my Mechanic's Manual (hope you know what I mean), didn't try it.
Hoffe, daß es bei allen, die's probieren auch funzt. Hab's nur ausm Werkstatthandbuch, aber nicht selber probiert.
Es grüßt Euch
Sven
Alt 04.06.2009, 00:14   #13
smateriato
There is not a service manual available? Just a pdf document.
Es ist kein Service-Handbuch zur Verfügung? Nur ein PDF-Dokument.
smateriato ist offline   Mit Zitat antworten
Alt 04.06.2009, 11:08   #14
...Which could be pretty much the same. One in Paper, and the other in electronical form. Doesn't really matter. Manual is manual... One can print out the majority of the pdf files, if one wants to do so.
... was so ziehmlich das selbe sein könnte. Eins in Papierform, das andere in elektronischer Form. Handbuch bleibt Handbuch... Man kann die meisten pdf ausdrucken, wenn man denn will.
Alt 04.06.2009, 23:47   #15
Sonny06011983
I got the service manual from Daihatsu, absolutely legal. Costs 75€ incl. shipping. It's a CD-ROM, the manual is in the Adobe .pdf-format. It's really great, everything you need to know to repair (or even modify) your car is in there.It's exactly the same what the mechanics in the Daihatsu garages are using.
I wrote a little review (sadly for you in german): http://www.daihatsu-forum.de/vbullet...kstatthandbuch
Es grüßt Euch
Sven
Alt 28.01.2024, 16:53   #16
Janinche83
Standard Subaru Justy
Zitat von Sonny06011983 Beitrag anzeigen
Hi there!
  1. Remove the key from the ignition lock. Remove negative battery terminal.
  2. Reconnect negative battery terminal and close all doors, if not already done.
  3. Within 15 seconds, press & hold both knobs on the transmitter simultaneously at least for 5 seconds, until the doors are locked & unlocked for confirmation.
  4. Within 5 seconds after confirmation, press & hold both knobs of the transmitter again for at least 1 second.
  5. For confirmation, doors will lock & unlock again.
  6. To register another transmitter (2 can be registered at a time), take the new one and got to step 3 again. Otherwise, registration will be done.
In Deutsch:
  1. Schlüssel vom Zündschloss anziehen.
  2. Negative Batterieklemme abklemmen und alle Türen schließen.
  3. Innerhalb von 15s beide Knöpfa am Sender gleicheztig für min. 5s drücken & festhalten; zur Bestätigung werden die Türen verriegelt und entriegelt.
  4. Innerhalb von 5s nach der Bestätigung die beiden Knöpfe erneut für min 1s gedrückt halten.
  5. Zur Bestätigung werden die Türen erneut verriegelt und entriegelt.
  6. Um einen zweiten Sender zu regeistrieren (zwei können gleichzeitig registriert werden), diesen nehmen und mit Schritt 3 fortfahren. Ansonsten in die Registrierung beendet.
Weiß jemand wie sich das bei einem Subaru Justy IV verhält, leider finde ich hier und auch bei Google keinerlei Info zu den Handsensoren, sie sind alle für Daihatsu und fürn den Justy nicht nutzbar 🥴
Janinche83 ist offline   Mit Zitat antworten
Welche Funkfernbedienung für L251 Havet Die Cuore Serie 45 27.12.2017 16:08
Funkfernbedienung nachrüsten bretti Die Cuore Serie 58 19.11.2011 20:42
Funkfernbedienung M3 pk-sirion Die Sirion Serie 9 10.09.2008 11:19
funkfernbedienung einbau? broadi Die Applause Serie 4 29.10.2006 12:10
Funkfernbedienung nachrüsten WundermichelYRV Die YRV Serie 2 16.05.2006 09:40
Alle Zeitangaben in WEZ +2. Es ist jetzt 09:01 Uhr.
