Alt 03.09.2005, 00:14   #1
Lennox
Standard Brake problem Charade '89
Dear Daihatsu lovers :)
I hope you all don't mind that I use English to ask this question. But i am unable to clearify the problem in German. The search was also not an option, because I could not find the german word for brake. I am really sorry.
The problem:
My litte brother is the proud owner of a '89 Charade (first car). The problem is that it has a seriously brake problem, and because of his small budget, i'd like to fix it for him. The sign in the dashboard gives the indication that the foult can be found due "a problem in the hydrolic system" If you put new brake "liquid" in the system, it works for some kilometers. But after some hits on the brake, the problem occurs again. Some of the liquid is also gone at that moment, but i can't find a leak in the system......
Are some of you charade drivers common with this problem?
I hope that you can help me with the tracing of this problem
Regards a Dutch neighbour.
Alt 03.09.2005, 01:28   #2
62/1
Benutzerbild von 62/1
Hello and welcome!
it is possible, that your problem is situatet at the rear brake. The G100 Charade (1987 - 1993) had brake-drums at the rear. In the drums there are break-cylinders. In each drum is one cylinder. These brake-cylinders can get leaking --- so you loose more and more brake-fluide.
best regards Rene
Alt 03.09.2005, 03:02   #3
charade 1,0
Benutzerbild von charade 1,0
As 62/1 already said, the break-cylinders in the break-drums could be the reason for the leaking break liquid. Check the inside of the rims for tracks of break-fluid or you park the car on a dry concrete surface, build up pressure in the breaking system by stepping on the break pedal and if it leaks you should be able to localise the leak more easily by the tracks on the ground. If the break pedal sinks down while you step on it but there is no lose of breaking fluid the break booster might be the problem aswell.
Nu isser weg....mein Charade...Nummer zwei lebt! bastelbaer Die Charade Serie 12 15.01.2009 00:30
charade spiegel problem baladeva Die Charade Serie 6 02.01.2009 23:53
News zum Hijet mit Charade Motor MrHijet Die HiJet Serie 35 29.10.2007 17:52
Problem mit dem Kühlsystem beim Charade 1,3CX markvamp Die Charade Serie 15 16.05.2007 07:46
Rost Nummero 3 - Die Charade G100 Krankheit MrHijet Die Charade Serie 24 09.05.2007 23:45
Alle Zeitangaben in WEZ +2. Es ist jetzt 10:20 Uhr.
