Alt 24.12.2007, 22:12   #1
fergie
Benutzerbild von fergie
Standard G101 TD parts needed
Hello All,
I am at the moment rebuilding a CL61 engine. For this I need a set of new pistons and connecting rodsas the gudion pins have worn and also the small end bushes. I have a quote from a local dealer (Holland) at 101 euro for a piston and 118 for a rod. Anyone out there in Germany who can knock that down a bit for me ?. Also need a oilpump.
Regards,
René.
Sorry for the english but my german ......:-(
Have : Charade 1.0 TD (Will be TDI) & Charade 1.3 4WD
Drive : Charade 1.3I 5D petrol (abba, A to B and B to A runabout)
Had in the past : Rocky 2,8 TDI van & Feroza Rezin top ELII, charade 1.0 petrol
Other hobby's include Ferguson Tractors & implements, Landrover MK3 ex UK army from the german base
Geändert von fergie (31.12.2007 um 17:16 Uhr)
fergie ist offline   Mit Zitat antworten
Alt 22.01.2008, 22:27   #2
fergie
Hello All,
After some searching I found new small end bushes are availeble. So I would just need pistons and gudion pins. Dai told me that these are DMA parts wich means they have to be re-manufactured. So it could take months or they may not even get made. So anyone got a set of new pistons laying about for me including the gudion pins ? Please ?
Regards,
René.
Alt 23.01.2008, 06:47   #3
Hi René
Please went to "Daihatsu Reindl" here in Austria, he has a big stock with old parts and maybe he can help you.
Send your request to: differentialrat@daihatsu-reindl.at and please also give Mr. Reindl the VIN (vehicle identify number), he will help you.
Reguards
Alt 23.01.2008, 16:59   #4
kiter
Benutzerbild von kiter
the problem is that nobody really like the diesel-engines, also nobody have any parts
Alt 23.01.2008, 22:15   #5
fergie
Hello Kitter,
I DO like the litle CL diesel engine ! I'm spending some good money to get it sorted. Will fit a intercooler as Fritz_s seems to have good results with that.
Regards,
René.
Alt 23.01.2008, 22:32   #6
JapanImports
Benutzerbild von JapanImports
normal Daihatsu Stores havnt Parts for your Diesel???
I mean new Parts, or u want only used parts?
but you can look @ all Ebay sites and mobile.de and autoscout24.de, for long time (4 months???) i have see a diesel there...
my english is bad
Alt 24.01.2008, 00:37   #7
fergie
Hello JapanImports,
Your english is prety good compaired to my german !.
The parts I need should be new. I've taken three of these engines apart and it's all the same, For example, gudion pin bearing play is specified as 0,0145 and I got 0,15 or similar. Aparently the parts take a real beating in these engines, so seccond hand parts won't do. I want to make it as good as new, I'm going to be driving it every day. Now Dai do not have these in stock anywhere, it's reported as a DMA. This means they have to be made if you want them. If I order these it may take two or three months or they may even not make them for lack of people who want the rest of them. (I suspect they wait until there are a certain number ordered before starting production).
I forgot to thank Rainer for the adress, I've e-mailed him right away , thanks !.
Regards,
René.
Geändert von fergie (24.01.2008 um 00:42 Uhr)
Alt 12.10.2008, 15:42   #8
wildbolz
do you have a current spare parts demand?
ps let me know, because I have a stock of older dai-parts.
re hw
wildbolz ist offline   Mit Zitat antworten
Alt 13.10.2008, 20:50   #9
fergie
Hello Wildbolz,
At the moment I could use :
small end bushes or complete rods (pref 6 of either)
camshaft (same as for CL11)
set of valves (same as for cl11)
So far been able to source :
2 new cylinder blocks with pistons and pins
new oil pump
undersize camshaft bearings
undersize crank and bigend bearings
1 new cylinder head (minus valves and camshaft!)
Regards,
René.
Alt 16.10.2008, 18:56   #10
fergie
Small end bushings sorted today.
Regards,
René.
Emissionsklasse G101 Turbodiesel Axi Die Charade Serie 6 10.03.2011 18:58
2x Charade TD, G101 fritz_s Die Charade Serie 12 15.10.2008 15:24
Parts 'n' Links Copen-Winner Die Copen Serie 1 02.01.2006 20:50
Kontrollämpchen spielen Verückt!!! (Massefehler???? G101 TD) Haussi Die Charade Serie 31 08.02.2004 14:30
Charade 1.0 TD mAx Die Charade Serie 5 08.01.2004 17:22
Alle Zeitangaben in WEZ +2. Es ist jetzt 23:31 Uhr.
