Alt 23.02.2009, 13:47   #1
smateriato
Frage 17" rims with 205/40 tires
Hello, I'm sorry but I'm in trouble to understand your language so I'm trying to translate in english using google translate
It's very hard and after many days I haven't understood the right choice about rims/tires
I have found this rims called RIAL VE or RIAL VIPER E with this specifications: 7.5Jx17 ET35.
The tires will be 205/40 R17. Only this dimension is admitted due to limitations in my country
Well, I'd like to know if this rims will cause troubles, but I'd like to know other rims specifications I can use with 205/40 R17 tires. 7J, 8J, ET30, ET40...
The next step will be the springs. I'd like to lower my Materia. I don't know how many cm. I have seen Eibach that is declared to lower 3cm. So I have to consider also this aspect when I will get the rims
Please give me a suggestion but also let me know your opinion about this rims.
Please also let me know what are you think about this rims with 205/40 R17 Pirelli P Zero Nero.
The price (rims+tires) will be 700 euro.
Thank you in advance.
Dateityp: jpg rial_viper_e_100.jpg (3,8 KB, 158x aufgerufen)
Dateityp: jpg Rial_Viper_E_6Jx15.jpg (3,6 KB, 157x aufgerufen)
smateriato ist offline   Mit Zitat antworten
Alt 24.02.2009, 01:29   #2
JUI
Benutzerbild von JUI
Standard 17" Felgen mit 205/40 R 17
Hey smateriato,
I can understand you,that you have problems with the german language !
I"will translate the message with your problems what you have with your rims and tires for the other user in german.Then they can answer more better and
I"will it translate back for you and hope that we can help you.
Please give me a little bit of time.
Now the translate from your message ! So good if I can !
Hier die Übersetzung deiner Nachricht ! So gut wie ich kann !
entschuldigung das ich nicht mit eurer Sprache klarkomme,so habe ich alles über google ins englische übersetzt.Das war echt heftig.
Nach vielen Tagen habe ich immer noch nicht verstanden,wie sich das mit den
Größen von Reifen und Felgen verhält.
Ich habe diese Felgen gefunden,die Rial VE oder Rial Viper E mit dieser
Bezeichnung 7,5J / 17 ET 35.
Die Reifen müssen 205 / 40 R 17 sein. Nur so ist es hier bei uns im Land genehmigt!
Gut, ich hätte gern gewußt ob es so Probleme gibt.
Dann hätte ich gern noch andere Felgengrößen gewußt,die ich mit den
205 / 40 R 17 fahren kann.:weißnix:
Der nächste Schritt wird im Frühling sein.Ich will meinen Materia tieferlegen.
Ich weiß nicht wie tief.Ich habe die Eibach,die 3 cm tieferlegt,gefunden.
Diesen Aspekt muß ich wohl mit einbeziehen,wenn ich diese Felgen bekomme.
Bitte hiermit um Rat,laßt mich eure Vorschläge wissen. ( Felgen/Reifen-Kombination )
Bitte laßt mich wissen , was ihr über diese Felgen mit den 205 / 40 R 17
Pirelli P Zero Nero denkt.
Der Preis ( für Felgen und Reifen ) ist 700,-Euro.
Danke fürs Bemühen,im vorraus!
Now you must wait for a answer ! Greetings to Italy ,Jui !
""" So, please a answer from special-people """
""" So , nun bitte ich mal die Spezialisten um eine Antwort """
Wenn es eben geht, dann bitte in Tabellenform und dann dahinter mit
einem ""YES oder NO"".( Oder mit Smilys )
Jui Jah Fari - ARTSTREAM - OVER - 3 . 3 5 0 . 7 5 0 - Views
(c) Spider Skull 10 by Jui Jah Fari, auf Flickr
Geändert von JUI (24.02.2009 um 01:39 Uhr) Grund: Nobody is perfect !
JUI ist offline   Mit Zitat antworten
Alt 24.02.2009, 12:23   #3
magnum
Benutzerbild von magnum
hi die felgen sind sehr schick!! würde allerdings an deiner stelle garnicht erst über 17 zöller nachdenken,sonder direkt nach den 18 zöller gucken. habe selbst 17 zöller bin auch sehr zufrieden damit wusste aber damals nicht das die 18 zöller so ohne probleme passen. jetzt weiss ich´s und ärgere mich etwas!! bei dir ist noch alles offen, also nimm die 18 zöller
lg thomas
Alt 24.02.2009, 12:48   #4
erloeser
Benutzerbild von erloeser
Blinzeln hallo smateriato
also, ich habe 215/35 R17 bereifung auf einer 7x17 zoll felge "Dotz Las Vegas dark" einpresstiefe 38, bei einer 30er eibach tiefelegung...
geht also ohne probleme...
...quadratisch, praktisch...GUT!
Geändert von erloeser (24.02.2009 um 12:52 Uhr)
erloeser ist offline   Mit Zitat antworten
Alt 24.02.2009, 13:38   #5
smateriato
Zitat von JUI Beitrag anzeigen
Hey smateriato,
Thank you very much JUI !!!
Not a problem for the time
I hope to receive answers even if the question is about an old issue
Alt 24.02.2009, 14:06   #6
JUI
@smateriato
We all have to learn from problems,so think every time good about problems !
That"s it,why we are stay here and talk together !
To be good friends !
That"s my car ! Have a look !
Dateityp: jpg Horror Drive.jpg (791,9 KB, 16x aufgerufen)
Dateityp: jpg 056 - Kopie (2).jpg (1,04 MB, 20x aufgerufen)
Geändert von JUI (04.09.2009 um 09:54 Uhr)
Alt 24.02.2009, 15:19   #7
321
Benutzerbild von 321
ET from 30-40 is ok - width of the rim schould be 7.5J max (I guess 8J might suit, too).
With those dimensions and 205 wide tyres lowering the Materia by 30-40mm is no problem.
And: You won't have to modify your wheel housings then.
Gruß! Thomas
Alt 24.02.2009, 15:26   #8
JUI
Thank you " 321 ".
" Dankeschön "an alle anderen ebenfalls!
Vielleicht hat der ein oder andere noch ein Paar " LINK s ". (Felgen Materia)
Geändert von JUI (24.02.2009 um 15:42 Uhr)
Alt 25.02.2009, 00:39   #9
JUI
@smateriato
Hey smateriato,
have a look here for rims+tires (automatic-machine)
http://213.209.128.250/points/(uutu5...qi)/start.aspx
Alt 25.02.2009, 09:44   #10
smateriato
@magnum
I'm sorry but I will receive the authorization only for 205/40 R17
@erloeser + @321
Thank you for your help and infos
@JUI
Many thanks for your help and also for the automatic configuration link
Now I have to wait the authorization and I have to find also the money
There is someone who knows a good dealer that ships to Italy? I'd like to check the prices because sometimes they are cheaper even if I have to add the shipping rates
Cuore L276 RIMS max11 Die Cuore Serie 0 22.12.2009 13:03
Alle Zeitangaben in WEZ +2. Es ist jetzt 11:23 Uhr.
