Alt 22.06.2005, 12:07   #11
levidrugi
I'm in Pécs, near the Croatian border, about 340 kms from sopron
Believe me, it has a Cat. I'll take some photos of the engine in the afternoon.
They didn't check anything. I took it to 3 diesel-specialist, the first said that it's simply old (12 years and 140 000 kms), the second said it's the turbo, and the third said it's a cylinder gasket. None of them even touched the car, none of them took any measurements, or anything.
BTW, how much would it cost to replace all cylinder gaskets?
levidrugi ist offline   Mit Zitat antworten
Alt 22.06.2005, 12:38   #12
Inday
Benutzerbild von Inday
Hey, that sound familiar with me. Our autoshops don't like to touch old cars with many kms either, they rather like to sell you a new showroom car.
I hadn't known that the situation is the same in Hungary as it is in Switzerland. :/
You might try again to take it in to another and smaller garage. They are rather helpful than the big autoshops; and sometimes they even do better and more reliable work.
Don't loose hope, insist with your problem in other garages. Was a qualified Daihatsu autoshop already investigating on it?
Cheers, Inday
Alt 22.06.2005, 12:42   #13
:) And belive me, i ´ve never seen one (and i worked over 10 years as daiahatsu mechanic !)
Anyway, the CL61 engibe is not the very best engine from daih.
Some known errors:
turbo failed (check the shaftplay) it´s from Aisin, not repairable....
pisten no. 2 died because of heating troubles
crakced head some reasen as above
Alt 22.06.2005, 13:08   #14
levidrugi
thanks for the quotes guys!
What are the signs if the turbo fails? I'm really worried, that the turbo may cause the problem!
I'll be back with some photos in the afternoon.
Alt 22.06.2005, 13:13   #15
Inday
I guess, when you remove the catalic converter, your engine runs well again (just teasing you!)
Cheers Inday
Alt 22.06.2005, 15:07   #16
Zitat von inday
Does the engine consume cooling fluid?
Zitat von levidrugi
yes, about half a litre every week
oh, i didn´t read this...
So in this it would be the head (gasket)....
Materia from Asia Tuned Die Materia Serie 10 28.12.2009 22:20
Alle Zeitangaben in WEZ +2. Es ist jetzt 01:54 Uhr.
