Alt 22.06.2005, 09:43   #1
levidrugi
Standard Charade TD white smoke, loss of power
Hello everyone!
Hope you don't mind that I write in english! I'm from hungary, and I'm an abolute Daihatsu fan!
One year ago I bought a 1993 Charade TD 1.0, the limited edition (full of extras, as it was the last few cars from the old series). Everything was fine with it, and I fell in love with the little monster! But a few months ago it started to smoke heavily, and it's not accelerating as it used to. Although the 4-5 litre consuption is still fine in the city, but I'm getting a little worried about it. Some mechaninc said it could be the turbo, another one said it could be the cylinder rings. I use Shell 10W40 oil in it. It starts fine, runs smoothly, does not owerheat, although the exhaust has a little puffing noise in it. Maybe it could be the Catalisator?
Please help me! Maybe you ran across a problem like mine before...
levidrugi ist offline   Mit Zitat antworten
Alt 22.06.2005, 10:30   #2
Inday
Benutzerbild von Inday
Hi @levidrugi
I am not quite sure about the abbreviation "TD". Does it stand for Turbo Diesel? Might it be that you have one of these rare Diesel engines in it?
If so then forget about the catalic converter since this only applies to gasoline driven engines.
However, should your Dai have a Diesel engine then you might use the search function since there were some issues with Diesel engines of your model in the past.
Cheers, Inday
Alt 22.06.2005, 10:42   #3
levidrugi
Zitat von Inday
Hi @levidrugi
If so then forget about the cathalic converter since this only applies to gasoline driven engines.
Cheers, Inday
Thanks for the reply!
It has a 0,993 litre turbo-diesel engine with catalisator! I'm absolutely sure about that!
I've tried searching, but with no luck yet.
Alt 22.06.2005, 10:56   #4
Benutzerbild von Sven
white smoke souds bad, could be the gasket from the cylinder head.
greets,
sven
Die letzte Stimme, die man hört, bevor die Welt explodiert, wird die Stimme eines Ingenieurs sein, der sagt: "Das ist technisch unmöglich!"
Sven ist offline   Mit Zitat antworten
Alt 22.06.2005, 10:58   #5
levidrugi
Zitat von Sven[seaman
]white smoke souds bad, could be the gasket from the cylinder head.
greets,
sven
what's gasket? the ring around the cylinder?
Alt 22.06.2005, 11:19   #6
Inday
Does the engine consume cooling fluid? I mean, do you have to add some liquid now and then?
Cheers, Inday
Alt 22.06.2005, 11:22   #7
levidrugi
yes, about half a litre every week
Alt 22.06.2005, 11:30   #8
Inday
As I can remember, this was a common problem with these type of engines. But I can't come to think of it what technical problem it was. The head gaskets? I guess so.
Have it checked at a Dai dealer, they will tell you how much it will be then.
Cheers, Inday
Alt 22.06.2005, 11:45   #9
levidrugi
BTW I don't know why you say it's such a rare car, in the city where I live in Hungary (pop.: 200 000) there are at least 20 cars like this (0.993 litre turbo diesel, well not the 1993 version, I own the only one :) (the dealer in austria said that this car was in the last 50 produced of the g101)
Alt 22.06.2005, 11:59   #10
Hi levidrugi
welcome an board !
Where are you from hungary?
I´m from from eisenstadt, not far away from sopron!
i´ve never seen a G101 with CL61 engine with Cat in my whole life, and belive ma, i´ve seen alot of them....
I think your turbo is gone, have checked the shaftplay already???
Materia from Asia Tuned Die Materia Serie 10 28.12.2009 22:20
Alle Zeitangaben in WEZ +2. Es ist jetzt 23:15 Uhr.
