Alt 21.04.2020, 21:08   #11
This engine have variable cam gear?
If it is a EJ-DE, then nothing at all is variable.
If it is a EJ-VE (probable, could not see it right in the Vid, because you didn't really film the view of the camshafts drive side...) then the Valve timing is variable.
Valve clearance is not variable in both types. To correct that, you would have to change shims on the upper end of each valve.
Alt 21.04.2020, 21:47   #12
dmpatanis
Shims is compatible or only in daihatsu i found it ?
dmpatanis ist offline   Mit Zitat antworten
Alt 22.04.2020, 18:58   #13
I don't know. But from what I saw, I guess you'd have to go to the Daihatsu Service Partner to get those.
But: First measure, then go and buy parts, at least, if you don't have to get a complete set. I don't know the details. Never had to do this.
richtiger pop off sound Turborädi Die Charade Serie 11 05.07.2017 10:56
Sound Einbau YRV dante-yvr Die YRV Serie 23 17.02.2007 21:35
Probleme mit sound..-.- AppiDriver~1986 Allgemein 10 25.09.2005 22:11
Remus Sound Frog1971 Die Applause Serie 4 10.07.2005 21:59
Sound im YRV Rainer Die YRV Serie 7 11.08.2003 19:22
Alle Zeitangaben in WEZ +2. Es ist jetzt 01:03 Uhr.
