Alt 10.04.2020, 17:17   #1
dmpatanis
Standard Ej-de 1000c1000cc tik-tik sound.
Hello the ej-de 1000cc when is cold after some hours at parking i can hear tik-tik-tik sound from engine.
After some km the noice disappear.
What is this noise?
Can i solve it.
dmpatanis ist offline   Mit Zitat antworten
Alt 17.04.2020, 11:25   #2
Bauer_Sucht_Sau
Excessive clearance due to cold temperature. This is normal, since the clearances will reduce through high-temperature expansion. This is why it's always best to only drive the vehicle at operating temperature. Driving with a cold engine will reduce engine life through excessive wear.
Just to be sure, why not show us a video?
Alt 19.04.2020, 19:38   #3
dmpatanis
I have video how to upload it?
Alt 19.04.2020, 21:21   #4
---> youtube.com ---> Upload --->Copy a link to the Video into this forum.
Alt 20.04.2020, 07:53   #5
Bauer_Sucht_Sau
Standard Step by step uploading
Click 3 times on the first image, in order to have it fully enlarge:
Dateityp: jpg Video_Erstell.jpg (264,2 KB, 8x aufgerufen)
Dateityp: jpg Video_Erstell_2.jpg (62,0 KB, 2x aufgerufen)
Dateityp: jpg Video_Erstell_3.jpg (134,8 KB, 2x aufgerufen)
Dateityp: jpg Video_Erstell_4.jpg (53,2 KB, 2x aufgerufen)
Dateityp: jpg Video_Erstell_5.jpg (110,8 KB, 2x aufgerufen)
Geändert von Bauer_Sucht_Sau (20.04.2020 um 07:57 Uhr)
Alt 20.04.2020, 16:38   #6
dmpatanis
I post a video of a sound.The video is in the morning after the engine sitting 12hours swithing off.
As you can hear as the engine get hotter the tik-tik sound disappear.
https://youtu.be/XTUHIiL1iNE
Alt 20.04.2020, 21:01   #7
Is it just after a long time (12h) or everytime when the motor is cold?
Alt 21.04.2020, 08:44   #8
Bauer_Sucht_Sau
I suspect, this could be tappet noise. I would remove the camshaft covers and then measure the valve clearances, while the engine is cold
Alt 21.04.2020, 11:25   #9
dmpatanis
When the motor is warm the sound disapearing.
This engine have variable cam gear?
Alt 21.04.2020, 13:45   #10
dmpatanis
With the warm engine no tik-tik sound
If i switch off and on again the engine when its warm the sound is the same.
https://youtu.be/uFuGzv3peCA
richtiger pop off sound Turborädi Die Charade Serie 11 05.07.2017 10:56
Sound Einbau YRV dante-yvr Die YRV Serie 23 17.02.2007 21:35
Probleme mit sound..-.- AppiDriver~1986 Allgemein 10 25.09.2005 22:11
Remus Sound Frog1971 Die Applause Serie 4 10.07.2005 21:59
Sound im YRV Rainer Die YRV Serie 7 11.08.2003 19:22
Alle Zeitangaben in WEZ +2. Es ist jetzt 07:01 Uhr.
