Alt 08.07.2007, 19:50   #1
CrashGTTi
Standard Hijet engine
hallo!!
i'm sorry but i don't write fine germany.....so i write in english:
What tipe of engine CB?? is on hijet?? And maybe have anybody pictures of engine............thank's
www.ccm.si
CrashGTTi ist offline   Mit Zitat antworten
Alt 09.07.2007, 00:53   #2
There are two types of CB Engines inside the Hijet: CB41 (Carburator) and CB42 (EFI).
Both are modified to fit to the Hijet mounting angle.
What details do you really need ? I am sure I can help you.
Cheers,
Alt 09.07.2007, 01:05   #3
CrashGTTi
aha.........thank's......
there are 2 verzion.......RWD and 4WD.....as the same engine?? CB??
details.........i have some idea for my new project..........to put in hijet engine of gtti......cb80......but only in RWD.........that we have here in Slowenien..........is there any problem if i move angle of gearbox??
last year i do that in Cuore :) gtti engine inside :)
Thank's
www.ccm.si
Alt 09.07.2007, 01:25   #4
RWD and 4WD is the same connection to the engine. You have to use the gearbox of the Hijet to adapt the CB80 Engine.
Only the 1.3 litre Engine and the Diesel versions do have a different gearbox connector. As long as you have a 1 Litre Hijet, you can adapt and CB80.
I am currently rebuilding an Charade (CB23) Engine to fit into a Hijet. I can send you a list of changes which I already done to fit the engine.
Cheers,
Alt 09.07.2007, 16:01   #5
CrashGTTi
Nice to hear that...........cb23 in to hijet..........what you do about angle of gearbox?? i look pictures of engine on hijet is not straight but have angle on/to driver side........i hope you understand what i mean.......
I give you on my kontakt list - MSN
If you send me changes list that be very nice.........can you please do some pictures when you be swap engine??
Is hijet and piaggo the same?? engine??
I think one option.........maybe in that piaggo (hijet) easy to do swap:
Or that tipe of hijet:
www.ccm.si
Alt 09.07.2007, 16:41   #6
Hi Crash,
Since 1993, The Piaggio Porter and the Daihatsu Hijet are build in Italy. Both are the same cars with just different manufactor stickers.
The Van and the Pickup engines are just slightly different. (e.g. the oil-filter is moved a little bit), so nothing to worry about.
The Gearbox of the Hijet is centered in the middle of the chassis, but the engine itselv is not verticaly, but kind of 45 degree build in. I can do some photos of it.
Cheers,
News zum Hijet mit Charade Motor MrHijet Die HiJet Serie 35 29.10.2007 18:52
Hijet - Genius und Wahnsinn mulxmilx Die HiJet Serie 30 09.04.2007 13:41
Prospekte zum Hijet MrHijet Die HiJet Serie 23 26.11.2005 14:18
Auspuffanlagen HiJet / Minibus S75 S84 S85 S86 MrHijet Die HiJet Serie 1 26.10.2005 00:57
Some Hijet Questions HoBuS Die HiJet Serie 1 26.01.2005 20:20
Alle Zeitangaben in WEZ +2. Es ist jetzt 21:59 Uhr.
