![]() Registriert seit: 09.09.2010
Hi
Im. sorry but my written German is very bad So I'll write in English. I've bought a GTti in 2009 it was a mess. I've changed thebodyshell and repaired the faults. Added some extras like custom downpipe and full stainlees steel exhaust, some gauges and BOV Currently the car makes 102,5PS on the dyno byt the AFR is about 14 so it needs to be reduced. Current pics. ![]() ![]() ![]() ![]() Uploaded with ImageShack.us I heve a problem now. My turbo boosts too much (0.9bar) instead of 0.6-0.7 I've done nothing to the ECU, so I dont know where is the problem. I chnged the solenoid but still nothing. When driving normaly the boost is about 0,5 but when i "push the pedal to the metal" it jumps to 0,9 - its not healthy for the engine. Where is the problem? |
hi, your problem is your downpipe !!
![]() Registriert seit: 15.03.2009
To correct your problem, you have to change the Wastegate...
Maybe you can make the hole much bigger or change the pressur tin(Wastegate-Actuator).
Charade G102 TX 1,3i(BJ91,Türkis, Aut.) Charade G100 TS 1,0i(BJ92,Silber) Charade G112 TXF 1,3i 4WD(BJ90,weis) Charade G112 SE 1,3i(BJ93,hellblau,Ami-Limo) Charade G100 Flash GTti(BJ88,rot) Charade G100 GTti(BJ90,schwarz) Charade G100 GTti(BJ89,rot) Charade G102 CX 1,3i(BJ92,schwarz) Charade G100 CS 1,0i(BJ92,schwarz, orig. Rostfrei) Charade G200 TX 1,3i(BJ97,rot) 2x Applause A101 4x Cuore L80 7x G100(RIP) Geändert von Axi (09.09.2010 um 20:33 Uhr) |
less restrictive exhaust> more boost !!!
#7 |
#8 |
built a fcd, than you won´t have the problems
#9 |
It's been a while :)
The car is currently being painted (NH -0 from Honda Integra) -big premiere next week:) Ive added adjustable coil-overs at the front (from Golf 3er) Changed some rubber parts in the suspension to polyurethane I also mounted a turbo-timer and rear strut brace (needs to be re-done) Pictures soon:) |
#10 |
Geändert von Miko (18.07.2011 um 21:44 Uhr) |
| Meine Gtti Restaurierung | turbotwin | Die Charade Serie | 42 | 19.07.2025 16:36 |
| Modellgeschichte/Unterschiede beim YRV | Rainer | Die YRV Serie | 26 | 03.12.2018 19:23 |
| Erfahrungsbericht Tieferlegungsfeder für YRV und YRV GTti | Rainer | Die YRV Serie | 96 | 29.05.2012 21:46 |
| Unterschied YRV 1.3TOP vs. YRV GTti | Rainer | Die YRV Serie | 25 | 24.02.2004 12:54 |
