Alt 10.02.2020, 09:50   #1
dmpatanis
Standard Oil in spark L7
Hello i changed spark in L701 and i noticed that in white part of spark was an oily.Is this a problem?
How i can fixed it?
Thanks
dmpatanis ist offline   Mit Zitat antworten
Alt 10.02.2020, 20:46   #2
There is a rubbergasket inside the valve cover - heat, age and oil destroy it over the years ... better look for another valve cover to fix that problem .
Greetings Mo .
Alt 10.02.2020, 21:51   #3
Bauer_Sucht_Sau
Ich glaube, er deutet eine verölte Zündkerze an
Zitat von dmpatanis Beitrag anzeigen
Hello i changed spark...
Are you referring to a spark plug?
Alt 10.02.2020, 22:26   #4
dmpatanis
Oily spark not in thread but in white end.
I notices 3 orings in valve cover?
Alt 11.02.2020, 07:55   #5
Bauer_Sucht_Sau
I see, now. The oil film is found on the engine's exterior. The rubber gaskets tend to become brittle. I had to replace mine also. They are not expensive
Alt 12.02.2020, 05:31   #6
dmpatanis
Yes but except of the rubber gasket there are and o rings rubber in spark plugs?
Alt 12.02.2020, 07:27   #7
Bauer_Sucht_Sau
No. The sparkplugs use a metal gasket. The oil is likely seeping out from one or both valve covers and is settling around the lowest point which is the sparkplug area. This was a typical fault with a similar FIAT design
Alt 12.02.2020, 10:28   #8
dmpatanis
Ok.Very beautiful motor.
If i want to not have oily spark i must change only the cover gasket?
Alt 12.02.2020, 12:02   #9
Bauer_Sucht_Sau
Yes. Before you remove the sparkplugs, you should apply solvent sourounding the plugs. Then, blow away the solvent and oil, using compressed air. Otherwise, you will risk debris entering the cylinder when the sparkplug has been removed
Alt 13.02.2020, 12:35   #10
As long as the Ignition works, you can save the money. On my L251 (same engine), I had always some Oil on top of the Spark Plugs. Never had an Issue with that.
As far as I know, there is pretty much no EJ-engine, which doesn't have that Oil seal leak against the spark plug, no matter if new or old.
Just wipe the Spark plug connector clean when it has been taken out.
Nissan Altima 2.5S - Spark Plugs Issue depprussell Allgemein 1 05.07.2018 08:56
Alle Zeitangaben in WEZ +2. Es ist jetzt 04:15 Uhr.
