Alt 19.03.2020, 08:43   #1
dmpatanis
Standard What tyres size i can install in my Cuore?
Hello in Cuore L701 automatic 4doors stock coils what rims and tyre size i can install? (It used with 4 persons inside)
Now i have 13" with 165/70 tyre.
If i put 15" i wll have problem in curbs?
Thanks
dmpatanis ist offline   Mit Zitat antworten
Alt 19.03.2020, 16:06   #2
Bauer_Sucht_Sau
It depends on the Tire Dimensions. There are 15" Tires available which are of nearly identicle Circumference to your original 13" ones. Cornering should be better, because the low profile 15" Tires won't flex as much. But, the Ride will suffer on Comfort
Alt 19.03.2020, 21:18   #3
Originally it should be 155/65 R13. I had 145/70 R13 on my L251, which is as good as identical in size.
What other sizes are legal, I have no Idea. There is for shure a 12inch size, which is the smallest possible that the manufacturer had installed on it and was approved for the model.
Alt 21.03.2020, 17:53   #4
Lupo
Benutzerbild von Lupo
Yes, that was 140 / 80-12
Alt 24.03.2020, 07:41   #5
dmpatanis
If i put 14" rims 6J et40 with 165/55 tyres?
Is this ok for cuore L701?
Alt 26.03.2020, 21:15   #6
dmpatanis
Can i install 14"rims
Alt 28.03.2020, 06:17   #7
dmpatanis
The rims that i found is 6Jx14 4x100 et38 can i install 165/55 tyres?
Thanks
Tyres pnol Die Charade Serie 4 25.02.2013 18:32
Das günstigste Fahranfänger-Auto / Der Cuore im Vergleich / Der beste Cuore? GustavGans Die Cuore Serie 4 25.10.2010 21:12
Size doesnt matter.... Rainer Die Copen Serie 18 30.03.2007 17:03
Will jemand Prospekte v.Cuore,Cuore TRXX,Charmant, Consorte? MrHijet Daihatsu Allgemein 0 19.10.2005 09:14
Engine size Peter_KTP Die Charade Serie 0 08.01.2005 22:55
Alle Zeitangaben in WEZ +2. Es ist jetzt 02:22 Uhr.
