Alt 30.03.2020, 20:46   #1
dmpatanis
Standard Cuore dont start easyli
Hello my L701 when its cold in the morning or after a long time with not running(2days) when i go to start my engine takes for example longer seconds to start than when its warm.
Why happens this.
dmpatanis ist offline   Mit Zitat antworten
Alt 30.03.2020, 21:41   #2
Is the engine in its factory state or did you modify anything?
Did you repair it or have you done any work on it, before the current situation arrived?
How old is the Battery, and how old the spark plugs?
Alt 31.03.2020, 09:06   #3
dmpatanis
The spark plug is new.
No mods.Factory
The battery its not new
When i turn the key,cold engine, takes 4sec to start and hot 2sec.
Alt 31.03.2020, 21:25   #4
that sounds not so unnormal for a cold 3-cylindered Engine to me. At least not, if the engine Oil is of a rather high viscosity. If you want an Engine to perform a Cold start within a Second, then get a for-cylinder.
Even when they come directly from the factory, these three-cylinders need a bit more time for a cold start than most of the four-cylinders.
I can't tell why, but I had a new cuore and an almost new Citroën C1, and both of those three-cilindered engines needed a Second or two longer to start than most other cars, which then were four-cylinders.
Alt 31.03.2020, 22:21   #5
dmpatanis
Ok.thanks a lot
start problene feigl Die Charade Serie 0 08.09.2006 18:34
Start Probleme Eib Die Charade Serie 10 07.04.2006 17:09
Start Probleme Eib Die Charade Serie 1 18.03.2006 22:28
Alle Zeitangaben in WEZ +2. Es ist jetzt 00:06 Uhr.
