Alt 21.04.2020, 12:06   #1
dmpatanis
Standard Cuore L701 cabin filter
Hello my cuore L701 1999mod has cabin air filter for aircontition and were is it?
dmpatanis ist offline   Mit Zitat antworten
Alt 21.04.2020, 20:58   #2
If present, it is behind the glovebox. That means, you have to take the glovebox away, and then you can see a Cover in the air duct, behind which you will find the filter.
But even in Switzerland, where often the comfort standard is slightly higher than in other countries, there was no Filter in factory state for the L251. If you wanted that, you had to puchase the Cover separately at the Dealership, and there was no customer information given officially. So I doubt if there was a cabin filter for the even older L7 at all. Have a look. If there is no cover, there will be no filter.
Alt 21.04.2020, 21:49   #3
dmpatanis
How i can remove the glovebox to look?
Alt 22.04.2020, 18:54   #4
Compress it on both sides on the upper part, then the glovebox will come out and you can lift it out of place. On its upper part on either side there is a plastic nose that holds it in place. Compress it so the noses can pass freely. Be careful to save the Plastic from breaking.
Fuel filter L701 dmpatanis Die Cuore Serie 3 12.02.2020 10:30
K&N Filter für L276 ? Teamgreen Die Cuore Serie 1 27.10.2009 09:52
Ölsote und Filter calledudweiler Die Copen Serie 5 15.09.2005 17:01
K&N Filter nx Die YRV Serie 11 25.08.2005 20:56
Alle Zeitangaben in WEZ +2. Es ist jetzt 19:04 Uhr.
