Die Copen Serie (L880)
Alt 27.01.2004, 20:24   #1
Standard COPEN Tuning auf japanisch...
WOOOOOW
was ich da gesehen habe..... COOL
Schaut euch mal die Seite
http://www.ks-sports.com/daihatsu.htm
an.
Hier einige beispiele, und für die die des japanischen nicht mächtig sind, auch gleich die übersetzung
The sportECU for copenXXYEN 88 and 000
Genuine ECU (engine control unit) with just it replaces (volt/bolt ON coupler ON) with 59kW (80ps both) 117N m (11. 9kg m) power & torque UP! < Measurement value inside the company D-sports >
Furthermore it is not necessary to put out genuine ECU to trade-in. Furthermore NGK 8th it belongs. It is possible to designate high power safely as the hand, without committing big risk.
In addition the modification point from of normal ECU is as follows.
Speed limiter: Cancellation : 9000rpm
Boost limiter: Approximately 1. 3K corresponding boost approximately 1. 0K
* After ECU exchange, it becomes ハイオク specification.
* It becomes not be able to use genuine.
(Domstrebe)
The rearperformancebar for copenXXYEN 26 and 000
The rear axle installation section of body side rigidity around the rear rapid by the fact that you tie UP. Function of the rear suspension is designated as more secure ones by the fact that rigidity of the suspension installation section is increased.
The occasion where the underside is modified and the occasion where suspension setting is done after installing the rear performance bar first, we recommend the fact that it does. If you rephrase, it is that much the part which has the effect.
Echt ein paar interessante sachen auf dieser Seite....
Having fun with it! :)
Alt 28.01.2004, 00:05   #2
kiter
Benutzerbild von kiter
boah nee...... irgendwann lern ich dochma japanisch
hossa, der überrollbügel un die sportgurte + schalensitze sin ma fett. so nen copen möcht ich auch haben... *gggggg*
Alt 28.01.2004, 13:19   #3
Teppi
ja öhm gibts nicht seit letzem jahr direkt ein offizielles rennen wo ausschliesslich roadster starten dürfen?!?
da war doch mal was...
Fahrt mit dem Copen von 2007 ins 2008!!! Copenliebling Die Copen Serie 10 08.01.2008 01:07
Neuer Daihatsu COPEN mit Linkslenkung bigmcmurph Daihatsu Deutschland 15 26.04.2006 12:27
Copen goes wild - Tuning Wagen aus Tokyo Val Brown Die Copen Serie 12 19.01.2005 23:46
Wieso Copen? Ping Die Copen Serie 11 07.09.2004 21:06
Alle Zeitangaben in WEZ +2. Es ist jetzt 12:22 Uhr.
