Alt 03.02.2020, 19:11   #1
dmpatanis
Standard Engine mounts L701
Hello when i accelarate i feel the engine goes up.
When i select R in transmission i have more vibration than D.
Which engine mount to replace?
The front one?
dmpatanis ist offline   Mit Zitat antworten
Alt 03.02.2020, 22:48   #2
Mostly the front one is damaged (90%). Most of the front ones have fractures. Nevertheless: Check also the back one.
Alt 03.02.2020, 23:10   #3
dmpatanis
Ok Thanks.
Where i can fount the OEM part number of a spare parts for my VIN car number?
Alt 03.02.2020, 23:14   #4
dmpatanis
Zitat von dmpatanis Beitrag anzeigen
Ok Thanks.
For example i have cuore 1000cc 1999mod auto
What oem code has the rear mount?
Alt 04.02.2020, 10:10   #5
dmpatanis
Which one is for my car cuore L701 automatic transmission?
12306-97203 or 12306-97210?
Alt 04.02.2020, 10:37   #6
Bauer_Sucht_Sau
We use "key numbers". If you scan your registration and show it to us, we can show you which numbers represent your vehicle. For example, the numbers representing mine are 7111 355. Most, if not all, Daihatsus have the same first numbers (7111). The second one defines your exact series
Alt 04.02.2020, 12:30   #7
Bauer_Sucht_Sau
I just found out that your registry numbers possibly will not coincide with those issued for Germany. I don't know if there is a European Union code for these. You can try using your vehicle identification number.
The following link explains how this system functions for German registry:
https://www.kfzteile24.de/magazin/ra...hsn-tsn-finden
The first four numbers only indicate the manufacturer. The first 3 numbers of the second set indicate the vehicle model (Cuore, MOVE, Sirion etc...). The last 5 numbers of that row will indicate option details of which your automatic transmission should be included:
Alt 04.02.2020, 12:59   #8
Bauer_Sucht_Sau
Standard If this helps
I just found this vehicle identification decoder. The results seem accurate:
http://vin-decoder.lv/JDAL601S000006679
https://duckduckgo.com/?q=jdal601s000006679&t=h_&ia=web
Alt 04.02.2020, 16:19   #9
dmpatanis
My vin number is
JDAL701S001020533
L701/GHDFW
Someone told me that the rear engine mount is diferent in manual than in auto.
Alt 04.02.2020, 17:59   #10
Moppi
12305-97210 Front
12306-97215 Rear
Engine flush henri Die YRV Serie 5 27.01.2015 18:10
A101 What to do? Engine compression 5.5 ! kamango Die Applause Serie 0 17.03.2009 21:26
Hijet engine CrashGTTi Die HiJet Serie 5 09.07.2007 16:41
Check Engine leuchtet!!! DJFlashBack Die Charade Serie 1 28.02.2005 15:59
Engine size Peter_KTP Die Charade Serie 0 08.01.2005 23:55
Alle Zeitangaben in WEZ +2. Es ist jetzt 03:36 Uhr.
