Alt 30.12.2003, 04:02   #11
superx
Dear YRV_driver
about the engine modification, I did following changed
HKS power flow and metal intake pipe
Apexi AFC = super air flow controller
Blitz Blow off Valve
FGK Power Getter exshaust
after above modification, the boost without the boost controller is about 0.9bar ~ 1.0bar (not stable enough). If have boost controller. I am sure will get 1.2 bar and make it more stable. But the coming stage, I am planning to put a body kit to make my YRV outlook more unique. For more information about the body kit that offering from Japan you can check this site out
http://www.vixi.co.jp/custom/yrv/aeromaster.html
enjoy
Paul
Alt 30.12.2003, 04:12   #12
superx
Dear MichlS
I am not sure is it call "charade" that same as yours A101
you may see their has some body kit for Daihatsu car in here
http://www.topmix.com.hk/db/Series.asp?id=5
when you see the model that which is same as your car, you may enlarge to see is it the same as yours.
Alt 30.12.2003, 09:24   #13
MichlS
@ superx
thanks for the reply and the link .. but "charade" bodyparts are not compatible to my a101 :(
bye
mike
Umbauten am L276 1.Cuore Die Cuore Serie 164 15.03.2020 15:58
L501 Rost am Schweller, drüberstreichen oder abschleifen KiLLerD.LüX Die Cuore Serie 16 09.04.2011 19:30
Sardine , Korsicka , Meer und mehr Terriblue 4WD/Offroadforum 18 23.12.2010 08:02
8. Internationales Daihatsu Treffen am 24. + 25.07.2010 martin j 25/07/10 8. Treffen / Neuwied 307 24.07.2010 11:36
Alle Zeitangaben in WEZ +2. Es ist jetzt 14:02 Uhr.
