![]() Registriert seit: 17.12.2019
Hello when i accelarate i feel the engine goes up.
When i select R in transmission i have more vibration than D. Which engine mount to replace? The front one? |
Mostly the front one is damaged (90%). Most of the front ones have fractures. Nevertheless: Check also the back one.
Ok Thanks.
Where i can fount the OEM part number of a spare parts for my VIN car number? |
Which one is for my car cuore L701 automatic transmission?
12306-97203 or 12306-97210? |
![]() Registriert seit: 07.12.2018
We use "key numbers". If you scan your registration and show it to us, we can show you which numbers represent your vehicle. For example, the numbers representing mine are 7111 355. Most, if not all, Daihatsus have the same first numbers (7111). The second one defines your exact series
#7 |
I just found out that your registry numbers possibly will not coincide with those issued for Germany. I don't know if there is a European Union code for these. You can try using your vehicle identification number.
The following link explains how this system functions for German registry: https://www.kfzteile24.de/magazin/ra...hsn-tsn-finden The first four numbers only indicate the manufacturer. The first 3 numbers of the second set indicate the vehicle model (Cuore, MOVE, Sirion etc...). The last 5 numbers of that row will indicate option details of which your automatic transmission should be included:
#8 |
I just found this vehicle identification decoder. The results seem accurate:
http://vin-decoder.lv/JDAL601S000006679 https://duckduckgo.com/?q=jdal601s000006679&t=h_&ia=web |
#9 |
My vin number is
JDAL701S001020533 L701/GHDFW Someone told me that the rear engine mount is diferent in manual than in auto. |
#10 |
![]() Registriert seit: 26.03.2004
12305-97210 Front
12306-97215 Rear |
| Engine flush | henri | Die YRV Serie | 5 | 27.01.2015 17:10 |
| A101 What to do? Engine compression 5.5 ! | kamango | Die Applause Serie | 0 | 17.03.2009 20:26 |
| Hijet engine | CrashGTTi | Die HiJet Serie | 5 | 09.07.2007 15:41 |
| Check Engine leuchtet!!! | DJFlashBack | Die Charade Serie | 1 | 28.02.2005 14:59 |
| Engine size | Peter_KTP | Die Charade Serie | 0 | 08.01.2005 22:55 |
